Fault - actuation for piston cooling GLE 250 2015
mattybb
coalville
vito 639 2012, GLE 250 2015
GLE 250 2015 OM651 anyone had this fault ?
I've had these two errors which i think might be the same thing or at least closely related.
P25AA00 - The actuation for piston cooling has a short circuit to ground.
P25A900 - the actuation for piston cooling has an electrical fault or an open circuit.
I have changed the solenoid valve this is related to as its relatively easy to change but it still brings up the above codes every now and again so i suspect its a wiring issue, just wondered if the are any common area's on the loom that cause issues ? thanks
