Fault code C2215
Deazley
Northern Ireland
2013 C220 Cdi
Hi folks, has anyone ever seen this fault code C2215 No or incorrect CAN message from control unit instrument cluster, I have sent the ABS module away for repairs two times to no avail.
Is it possible it's a steering angle fault code ?
Different scanners show different codes , what did you use ?
I used Delphi, pass no remarks on the wheel speed sensor fault in the pic it has been repaired
1117 may well flag up 2215.
If you are interrogating ABS and it is reporting a missing CAN message from another module, you can assume there is nothing wrong with the CAN on the ABS, after all you're communicating via that CAN interface to get those codes.
Does the cluster report similar error? What's inbetween the ABS and cluster, is there a gateway?
No fault codes at all on the instrument cluster, I done a continuity test from the cluster to the ABS unit and I seem to be getting all wires ok, I'm ready for the mental hospital at this stage
