fault code P204F96 Gle coupe 2017 350d
Marvellous
london
Mercedes Gle 2017 coupe 350d
Hi
I have fault code P204F96 The adblue (cylinder Bank 1) system has a malfunction. That the reading I had when i took the car to a garage after i filed up the adblue tank. issue did not go away. I had less than 200 miles before engine would not be able to start again. The system worked fine for a day after the fault code was cleared. when I started the car in the morning, issue had come back again. engine light came back on. I'm going to take out the nox sensor and clean it with a carbon fluid cleaner , i believe there is only one nox sensor upstream of the catalytic converter. If that does not work then i will have to take it to dealership. car not under warranty due to salvage car ( but unrecorded). Anyone have any information or fixs for this fault code?
There are TWO Nox Sensors. One upstream and one downstream. Recently had both of mine replaced. Can't remember exactly... but cost over £1,500
