Fault codes W210 E430
hanns gruber
Benfleet essex
E43 W210 Avantgarde
Hi i have these codes to track down in the system and fix:
B1010 - Supply voltage of the control unit, i have changed the battery.
B1147 - Output terminal 15 has short circuit - does anyone know where on the car this is? and what to do?
C1022 - fault in CAN communication with control?
i have posted this in other parts of the forum but i dont seem to have much luck.
jaymanek
Nuneaton Warwickshire
15 is one of your main lives (ignition I think?).. if this was not really working, your car wouldnt start.
OP
OP
hanns gruber
hanns gruber
Benfleet essex
E43 W210 Avantgarde
limit on revs at 4k in every gear, BAS ESP and Antilock lights come on.
you say that about ingnition, my stalk with the cruise control and single stalk (indicator etc) the surround is loose.
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Those codes do not reall mean that much. The live data needs to be checked really. The loose st.column controls will not help either.
BlackC55
Not without checking it myself with a Star. It could be so many things and probably related to the other faults.
OP
OP
hanns gruber
hanns gruber
Benfleet essex
E43 W210 Avantgarde
how much do you charge to have a look? MB want a ridiculous amount to "further investigate"
