Fault Codes
david b
Anyone know the fault codes
P20038
P2061
p2062
Not sure that the p20038 is a code, but there is a p2038.
p2061,Reductant Injection Air Pump Control Circuit High
p2062, Reductant Supply Control Circuit/Open.
p2038,Reductant Injection Air Pressure Sensor Circuit Range/Performance.
Are these codes from a Kompressor engine?
Yes a Kompressor engine
P20038 comes up as Oxygen sensor downsteam of 3 way cat
where is this located? would it just need cleaning or replacing?
car runs perfectly
P2061 comes up as Alt
P2062 comes up as Alt
I had the Alt pulley replaced as it was faulty some time ago
this seems to refer to that?
