Hey guys.
Wonder if you can help. My air con hasn't been working for a 6+ months now. So I decided to get it re gassed today at ATS. Can't fault the service. But the air con still doesn't work. Now the previous results off the testing machine showed I had 300gm out of the 595gm. It showed no leaks and everything was in place and good working order. And the last time it was gassed was when brought in 2007. So I assume it can't have a leak, otherwise it'd be completely empty being 9 years old?
So does anyone know why it's not working? The light comes on as it should, the blowers work fine and the car was diagnosticed to remove any faults and to re set the air con (didn't showing anything and had the reset done).
Also could it be a fuse? Or condenser? Any help would be appreciated.
Cheers
Ash
Cheers
Ash
