Faulty clutch: Can I claim for expenses?
Discussion in 'OT (OFF Topic) Forums' started by Antharro, Jun 16, 2016.
  1. Antharro
    Antharro Hardcore MB Enthusiast
    176
    Oct 3, 2008
    Ferndown, Dorset
    Car:
    '95 Mitsubishi FTO GPX, '92 Honda Accord Aerodeck, '78 Mercedes 350SL
    Hoping you guys can help me out here. :)
    I recently bought a clutch from a seller on eBay. Seller had good feedback, it was a branded clutch (Exedy). I had the seller confirm it was the correct clutch for the car before buying. It arrived, took it to my mechanic to fit. He fitted it. Told me it was the wrong one and didn't work when it was fitted. Took it out, put it side by side with the old clutch, said it was smaller than the original and figured it was probably a mis-packed box.
    I arranged a return through eBay and it's on its way back to him now. As this has cost me a significant amount of labour, I would like to claim some of it back from the seller. I've messaged him through eBay asking him to contribute £300 towards the labour incurred, will see if he replies. If he doesn't or won't pay up, do I have any legal options?
  2. brucemillar
    brucemillar MB Club Veteran
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    I suspect you have no real probability of getting any return here. Best bet is to open an eBay dispute "item not as described" that will only get you a replacement or money back.
    No different to buying from a shop.
  3. OP
    OP
    Antharro
    176
    Oct 3, 2008
    Ferndown, Dorset
    Car:
    Oh, he's taking it back on eBay - I opened a return against the item and it's on its way back to him, by courier, paid for by him. I do appreciate that things go wrong sometimes, but I also expect people to rectify the situation when they do go wrong.
  4. ash59fifty-uk
    ash59fifty-uk Hardcore MB Enthusiast
    3,678
    Aug 9, 2015
    The shire
    Car:
    W204 C63, Ford Transit
    I'd say there's a small chance of that
    Why didn't the mechanic marry them up before fitting the new one?
    The notion of checking them side by side AFTER fitting seems a bit of a chocolate teapot thought
  5. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    If the mechanic has fitted a new one, having just taken off the old one and not realised they're not the same, I'd be after my money back from the mechanic.
  6. OP
    OP
    Antharro
    176
    Oct 3, 2008
    Ferndown, Dorset
    Car:
    @ash59fifty-uk , @i-CONICA - good points both. I hadn't considered that. I think I will need to have a conversation with him.
  7. ash59fifty-uk
    3,678
    Aug 9, 2015
    The shire
    Car:
    Fault here is definitely on the mechanic
    If I ask for a quarter pounder at McDonald's and receive a regular crown on my burger, the faults with the kitchen crew not the bun company
  8. Red C220
    Red C220 Hardcore MB Enthusiast
    4,197
    Jul 30, 2011
    Surrey
    Car:
    2015 SL400 : 2017 S6 Avant
    When you buy an item the liability for any potential loss it generally limited to the cost of the item itself. i.e the initial cost of the item in total including delivery.
    What you're asking for is a contribution towards consequential loss. This is where things start to get sketchy.
    You've bought a part from eBay, there are two duties of care taking place here:-
    Duty of care 1 - The seller has described the goods correctly and the goods supplied are as described.
    Duty of Care 2 - The buyer has read the listing in full and has understood the item being bought is the correct item for their use.
    If duty of care 1 hasn't been complied with you have the right to return the goods for a full refund.
    If duty of care 2 hasn't been complied with you have the the right to return the goods for a full refund as long as they are in a condition that will allow the seller to offer the product for sale again in the original condition as supplied.
    So in short, unless you can demonstrate you have suffered material loss* you're unlikely to be able to claim for anything other than the original cost of the part.
    *If you choose to employ a third party to fit the part you bought, this is not responsibility of the seller of the original part.
    2 people like this.
  9. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    Even if he assumed it was right, and didn't compare before fitting the new one, the wear marks on the flywheel should have given it away.
  10. st13phil
    st13phil MB Club Veteran
    7,987
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
    Not necessarily. It depends what the difference is. Sometimes its not immediately obvious unless the two units are closely examined side by side, and even then it's sometimes necessary to measure component features before small differences become clear. And the mechanic is unlikely to do anything other than take a cursory look at the components for signs of obvious damage if they have been supplied boxed and marked up as being the correct ones.
    As an aside, this is a good example of why getting the mechanic to both supply and fit is helpful: If something goes wrong, the mechanic bears all risk - which, incidentally, is why they may charge slightly more than the aggregate cost of a labour only job with the customer supplying the part(s).
  11. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    but as i said, when you offer up the friction plate to the flywheel, you'd see the shiny bit extends out beyond the edge of your new plate, making it immediately obvious it's smaller than the one you just took off.
  12. Wayne.clk
    Wayne.clk Hardcore MB Enthusiast
    136
    May 11, 2014
    Car:
    Clk
    In no way is the mechanic at fault, there is no way he will know it's the wrong part until the old one is removed so there for labour charge will still stand.
    You supplied the part so I'm afraid he was only doing as instructed by yourself
    It's the chance you take when you supply parts.
    Fault lies with the supplier, doubt your get any money from him though
  13. merc85
    merc85 MB Club Veteran
    7,827
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    So is the car still in bits? or has the mechanic put the old unit back in?
    I'm so glad we don't Sell items on ebay as it can simply be a nightmare for very little profit, Paypal can now refund items upto 180 days after the sale too if the buyer makes a claim.
  14. d w124
    d w124 MB Club Veteran
    12,366
    Dec 30, 2008
    london
    Car:
    w124 3.6AMG styling E320 S124 Lorinser styling
    Had the mechanic bought the part than yes but that's not the case here
  15. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    If a joiner hammered your square peg into your round hole, wouldn't you argue he should have stopped before, and informed you that your square peg is wrong?
    Obviously labour is still owed. I had the same happen to me, and my mechanic called me, told me it's wrong and said he can get the right one from ECP in a couple of hours. We did that, and I got my unused clutch friction plate back.
    Labour was the same as it would have been, with a couple hour break in the middle.
Share This Page
