design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
Hello All,
I have recently had new tyres fitted, I did have an issue with a slow leak in the rear tyre but after changing the valve it seemed fine, I was able to check and add pressure when required. Just recently I went to check the tyre pressure and found I could inflate all of them except one tyre. I used the service stations and my own electric tyre machine compressor, my pump will work on all the wheels except the rear tyre in question and same results when using the service station pumps.
The valve was fine when fitted and worked for several weeks I did give it a wash thinking something was lodged in there, I can push the pin and it will release air but it will not allow me to add air.
Any thoughts or possible causes. Tyre is not completely flat but has reached 20psi.
