I do. Still the same...Don't pull the trigger fully back
Bought this car recently... I heard something about carister valve behind the wheel but checked today and don't see it. Only add on tank...Has it always been like that, or has it just started doing it?
How can I check it?Hi ,just a small chance but has a previous owner installed an anti Syphon device ( that's failed) in the fuel pipe.
Mine is under warranty too. Do you think they should fix it for free?I have the same problem and its going in to mercedes Warrington next week to see if they can sort it out as its still under warranty. It can take upto10 mins to put £30 in and anyone waiting behind gets very frustrated as do i![]()
Well mines going in to Warrington mercedes on the 8th for them to look at with the same problem under the warranty. If you cant get fuel in properly then the car is not fit for purpose !Mine is under warranty too. Do you think they should fix it for free?
Hello. Did they fix? Can you update pleaseWell mines going in to Warrington mercedes on the 8th for them to look at with the same problem under the warranty. If you cant get fuel in properly then the car is not fit for purpose !
