It's a queue! Lets just forget it.....9 minutes...if there are three chargers.
The EV market would be change forever in just one minute !The claim of a 1 minute charge time is incredible...and if true would change the ev market at a stroke.
Same here, saw one in Belgium some years ago. My guess is there is a bloody good reason for them being so rare....I've only seen one Fiskers so far and it wasn't even in UK, so I doubt there will be queues to charge them ;-)
The current flow for 1 min charge would be so high it couldn't be possible unless you happen to have an electricity pylon in your back garden. Then the battery has to be able to accept that charge rate. Sounds more dangerous than an F1 pit stop refueling.
That's often talked about in the way to recycle EV batteries at their EOL, say after 8-9 years the battery doesn't hold 75% any more, which is where the car owner would want it replaced, it's still plenty to be used in a bank of batteries at a charging station.There are lots of nay-sayers and doom merchants, but it is possible to envision a future where there are lots of high capacity chargers installed all over the shop. These invariably have to include large battery packs in order to supply these huge spikes of power, so what you end up with is a very large amount of battery packs connected to the grid, gently filling up, ready to charge cars. This is happening right now, albeit it slowly. What a great way to even out electricity demand and soak up excess, as well as make up for shortfalls in generation from time to time.
The barriers to that aren't really technical - the stuff already exists, principally a matter of scale, and that is mostly political/financial I think. There other issues of course, mostly around the rare-earth metals used in batteries, but manufacturers are working on that.
I saw that! Think it was on Netflix, was interesting the see the physics of LiPo and LiIon, as I only knew the practical differences before. As with most things if there's a business need for something and funding available, science usually finds a new better way to do it - look at hybrid tech advance since F1 took it on. We'll have some amazing energy storage in 10 years.I saw an interesting demo of an alternative design of Lithium Ion battery the other day. It uses a plastic electrolyte/barrier rather than liquid, which means it can be crushed/punctured/cut without catching fire. It even continued to supply power after most of it had been cut away. Very prototype at this stage, so no guarantee it can be scaled up, but it looked promising. Also, as it uses a solid membrane, it was able to use solid metal lithium as the electrode, meaning it could offer twice the energy density of the more common chemistry that uses ionic lithium in a carbon substrate.
