done a search, but couldn't find what i needed
I need to replace the n/s wing mirror glass, hows this done on a none folding w203 coupe? can't see how to remove the wing mirror housing
any help appreciated
I am told it can be done without removing the mirror cover but I tried and could not do it so to do it my way...
Fold the mirror toward the door; look inside and you will see a chrome spring clip about 3/4 of an inch wide.
Lever this with a flat bladed screwdriver and slide the mirror cover off.
This will reveal the long spring clip that holds the mirror glass in place; pretty obvious from that point on.
Hi, not too sure if its the same on your model, but on my CL, I put a flat screwdriver under the mirror and lifted it upwards towards the top of the mirror housing and the mirror popped off, don't use too much force. There is a metal cable that clips onto a plastic bracket. Hope it helps, although im sure someone here knows the exact procedure for your car.
my car doesn't have the auto fold option. when i manually fold it in and hold it there, i don't see and 3/4" chrome spring clip....any ideas to get the housing off or an easier way to fit the glass?
Erm... mine docent have auto fold either. I just fold it manually and the clip is visible.
There is another post on here somewhere for a 210 which is the same procedure. I will try to find it and post a link.
