The electronic climate control panel on our old A4 has been playing up ... intermittent display, and buttons not working. A new one probably costs more than the car is worth!
Tried to find a replacement on eBay but unable to match the one in our car (even for the same year there are various different part nos.).
So ... I decided to carefully open the unit up and see if I could see anything obvious.
Where a ribbon cable connector meets the display panel I found 3 or 4 fractured solder joints on the back of the PCB ... here's one:
Re-soldered all the connections (to be on the safe side), put it back together again, and it worked! :bannana:
From start to finish the whole thing took less than 30 mins.
OK so the blower has now died but we are one step closer to being able de-mist the windows again
Seems the brushes go on the blower motor (as they do on M-Bs) ... hopefully a fairly straightforward fix.
