Barbanasos
I ve just been off for nearly three weeks and after coming back my 55amg has a totaly flat battery. I do not use the car daily which did not help before going on holiday. Which is the safest and appropriate way to deal with this?
Shall I unlock with the metalic part of the key? (What happens to the alarm as not even sure if the central locking will work hence only the drivers door will unlock).
When I unlock the car is it simply a matter of jump starting it using the positive connector at the front and somewhere on the chasis? I hope that does not affect the electronics, i.e does the key need to be out of the ignition when I attach the cables or at a particular position?
I hope someone can help.
Thanks.
Thanks.
