Flatfacedbolts
Colin Borley
Peterborough
C180 2002 w203 saloon blue
On my C180 I have ET25 flatface wheels. I need one more long wheel bolt ( the ones with the long shank between hex nut and mushroom. Can anyone help please.
Colin Borley
Colin Borley
How long are they - can you send a picture,.
I have a full set of extra long bolts- as used on the CLK if 18" AMG flat face wheels fitted.
These were intended for rear wheels if 10mm spacers were used ( i think on the CLK convertable only for some reason)
Gunny
I have loads of different sized wheel bolts. All doing absolutly nothing. Could you post the size and I will see If I have any similar.
I have plenty of these...Same as fitted to a facelift 126 or 107...
here is a pic colin sent to my inbox:
tee hee - they are the bolts that Mercedes no longer recommend you to use.
as they have got older and have been abused by people with air wrenches etc many of them have snapped halfway down the shaft making removal an absolute pain.
I was told in no uncertain terms not to use them by my dealer when I asked him for some replacements.
Andy
the replacements are short ones without the centre shaft - sadly they don't fit flush with the flat face wheels.
I couldn't even find an aftermarket supplier selling the extended bolts either with my local wheel specialist telling me the same thing and that the only two people who manufactured them had stopped.
Andy
MB do still produce them, i get them in all the time, still sell loads, and have only ever seen one snap half way down the shaft...
What you must be referring to as the replacements are what is on most W124's, 202's, 210's etc...
Flatfacewheelbolts
Dear V12
Thanks for info. How do I get one, do I order it through you ?
If anyone wants a FREE ET44 flatface wheel rim painted and ready to use, I have one. I now have 4 ET25's but just need one long bolt to complete.
Regards Colin
Flatfacewheelbolts
Andy
Andy
Thanks, looks like V12 has the answer
Colin
ET25 flatfaced wheel bolts
Ian
Thanks for reply. Can you get an idea from picture. If not my address is xx xxxx Road Folksworth Peterborough Cambs PE7 xxx 01733 xxxxxx
Colin
Edited your address! Please PM Ian instead of publicly posting! (for your own saftey)
