Fluctuating Revs
trainer
Staffordshire
C32 AMG - Sold October 2013
For a short period after starting, say 10-15 minutes, the revs are fluctuating quite noticeably.
Any ideas?
Hard to say mate.
An independent diagnosed similar symptoms as defective coils.
Paid £40 for the diagnosis.
Left it for while. A different garage said, I am paraphrasing, "if you have a misfire, the unburnt fuel may damage the cat"
So I shell out £200 for coils and the labour
Outcome...The guy says there is no misfire, but I can tell you the flucutation on the rev counter is still there!
-- D
Might be worth cleaning the throttle body and flap out with carb cleaner and a toothbrush.
Done this on a few of wifes old cars all to cure uneven idle or low speed shunting problems.
Lynall
i had this problem with a 406 ended up having a new stepper motor.
Many things can cause this fault but the most common issue is a vacuum leak.
Good point as when doing my injectors the other day my revs were up and down then i saw i had the plastic hose of the purge valve.
I also noticed a few of the little vacuum hoses at the front of the inlet manifold were perishing, not holed but not good either so i replaced them.
Quite a few hoses at the back of the manifold as well.
Lynall
I still have the fluctuating revs on idle. Please can you help me locate the throttle body? (W208.365) Once I know where it is and what it looks like I will have a go at cleaning it! :)
I have bought one of those service / maintenance manuals (DVD) from ebay. Looking forward to knowing a lot more! :)
If it the v6 motor its at the back of the inlet manifold, when i did mine v8 i unplugged it and it took the car while to relearn the throttle settings so had to put up with high idle for a few days then a long run to dover and back sorted it out.
If i was doing it again i would not unplug it but unbolt it and clean it whilst still attached to the loom, carb cleaner and a toothbrush.
Lynall
