I bought this monitor a while ago, with a view to fix to either OCP / headlining or top of the dash, however it just didn't look right, plus I already have a fixed stand Garmin satnav on my dashboard ...
Anyway - new, never used/installed in a car, boxed. Tested, so the protective film was removed (and re-applied) from the screen. No bad pixels, or any other faults.
3M adhesive base as seen in the pictures, rotating 360º so can be fixed as desired.
Don't expect 4K quality - the screen is 4.3" and resolution is 480x272 - enough to see what you're reversing into.
It has two video inputs and switches to rear view cam automatically once the reverse gear is selected.
Comes with a brief manual with wiring diagram.
Please note, I removed the [horribly bright] TFT sticker from the monitor, and placed it onto protective film, so it can be put back, if so inclined.
Includes power (12V) cable (forgot to photograph, but it's there).
If powered correctly, can be used as home/garden/garage etc, monitor.
£10 incl. postage in the UK
