wongl
Retrofitted folding mirrors to a W169 Classic this weekend with the help of a seasoned MB Mechanic. We fitted new folding mirrors (A1698101376 LHS and A1698101476 RHS). Hardest part was getting the old painted cover off the old mirrors to refit on the new folding mirror frames. Quite easy to break the clips.
Second, replaced the door control modules with A1699000500 LHS and A169000700 RHS.
Third, replaced the door control switch with one with the folding button A1698206710 9174. Tricky job to remove the switch facial from the two window module over to the four window/folding switch.
Found that the new door module would not work as it should- swapping them over worked, but the left button operated the right window etc. Fitting them to the correct sides would not work with Star reporting both Faults on both door modules. In a desperate attempt, I modified the door control modules settings with Star and reloaded the settings to the modules. To my surprise this action caused the module to start working as it should! Not sure why?
Finally modified the Variant coding to enable the Folding mirror menu so that auto folding can be enabled/disabled under the Convenience menu. All working as it should now.
Total cost came to circa £320 as I managed to source most of the parts on eBay over a number of months. :bannana:
Next project is to get the headlights to come on with the locking the car. Found the settings to enable the menu for this but either missing another setting or one of the modules requires upgrading. Given that the light sensor already controls the headlights, I am hoping that this can be enabled via modifying the settings without having to replace another electronic module.
