- Feb 22, 2010
- Location
- Stirling, Scotland
- E55 AMG W211, E250 Sport W212, (and some Imps)
Our trusty old (2002) Ford Transit has been making a bit of a noise from the clutch for the past wee while.
We were not 100% sure if it had a Dual Mass Flywheel (DMF) fitted so we had decided we would drive it till it stops then take it from there.
Clutch pedal went to the floor yesterday so it was time to park it up and have a look.
Stripped it today for further investigation.
After we got the gearbox out, then the pressure plate we seen it had a DMF but we could not get to the bolts that held this on as it was locked at the wrong angle.
Had to get the grinder out and cut away sections so we could get into the bolts.
You can see here where we have had to cut.
Not too much wear on the friction plate but it would seem there is another reason for the catastrophic failure.
OK you can't see the pressure plate but you get the idea.
The release bearing / slave cylinder assembly is rotten and rusty, bearing sounded like metal to metal rubbing.
A look at behind the flywheel shows a lot of rust, looks like water is getting in at the top (Crank Position Sensor possible) and then pooling in the bell housing and rotting things. Need to investigate before we get it back together.
Quite an expensive/awkward repair this, £176 for a flywheel, £276 for a clutch/cylinder/bearing, £11 for bolts plus all the other little bits we have found to do with the front suspension.
I hate dealing with ECP but just seen that they may have the DMF for £110 so may give them a try again.
Should be able to get the clutch and cylinder cheaper as well so going to try and save what we can and spend the savings on suspension parts.
Wish us luck.
Wish us luck.
