formatting to fat32
mercmanuk
MIDDLETON MANCHESTER
C180 AVANTGARDE SE SPORT GONE AND MISSED LANDROVER FREELANDER 2 LET IT SNOW LET IT SNOW LET IT SNOW
how can i format a 500gb hdd to fat32 rather then ntfs file system,ive a media streamer and it will only accept a hdd with fat 32,i understand about the 30gd linmit with fat32
cheers again
so does it mean if you make it a FAT32 your 500gb will only be able to do 32gb?
It means your file size can't be bigger than about 4.5 gig.
Have you tried right clicking on it, going to format and then picking fat32?
Don't think Windows will let you do it, you need a hard drive manufacturer's app to format it in DOS or something. Done it before but then had file size problems with ISOs as above.
hi there mate.
attached is a command line based tool to format with FAT32, when the partition is bigger than 32GB
Cheers
Why not split the 500GB HDD into 2 or more partitions, one of which can be 30GB for your FAT 32 - you can then Format the other(s) as NTFS if you wish.
Partition Magic would be needed to do this.
because he'd most likely want to use all the capacity with the media player he has and that device wouldn't read anything but FAT32.
browsing multiple partitions (15 - 16 partitions in this case) might be (no, will be) very annoying if the device does not index files from all partitions into one big list.
