14 plate E250 I'll updateDo you think it might help with the answers you are looking for if you mentioned the vehicle model?
Go to YouTube and watch a couple for your model car first is a good start point .Hi All,
Going to change my front brake discs I've done the pads before but not the discs. Anything to be aware off and is 115nm the correct torque for caliper carrier?
Agreed. I recently bought Brembo discs and pads from AutoDoc at a good price. They arrived quick enough for me (just over a week) but there are plenty negative reviews from people unable to plan ahead who expected their purchases delivered within 24 hours!You will get all sorts of views on what disc's and pads to fit. So here is my input, Brembo parts all the way, make sure the hub faces are shiny and clean. I buy from Autodoc, watch for their discount offers to get a decent price.
I just couldn't undo the disk bolts with the tools that I had.
Really needed an extension bar on the socket, also, car was just up on axel stand so not enough room to get any real leaverage.
Top tip - always try and loosen the disc retaining bolt before dis-assembling anything else. That way you can have someone in the car to hold the disc still by pressing the footbrake to ensure better grip with the torx bit as there is more opposite force/resistance from the diskI presume you mean the caliper mounting bolts ? Mine were seriously tight. I managed to shift them by turning the wheel to full lock for better access. Can't remember exactly what I used but I'll have bodged it with whatever length of steel tube I could find as an extension bar. I've got a vague recollection that the head of the bolts was relatively shallow. On a job like that I'll be prepared to grind the lead in bevel off the end of the socket in order for it to get maximum purchase on the bolt.
The other bit of fun was one of the disc retaining screws came out reasonably easily and the other one refused to move and ended up damaged after snapping my Torx bit. It was easy to take the head off with a sharp drill bit and then once the disc was off, remove what was left with vice grips. New screws came with the discs.
Alternatively, especially if there’s nobody else around to help, a screwdriver between the inner flanges of the disc and the calliper does a good job of locking the disc whilst undoing the small retaining screw.Top tip - always try and loosen the disc retaining bolt before dis-assembling anything else. That way you can have someone in the car to hold the disc still by pressing the footbrake to ensure better grip with the torx bit as there is more opposite force/resistance from the disk
There are also plenty of negative reviews about them delivering non standard or poor quality parts rather than the purchased ones, people finding it next to impossible to get refunds, parts no arriving etc etc. I personally gave them a second chance after a driveshaft was delivered that was so poor quality it could not be used and then they took a month after return to give me the refund.......only to be let down again on shock absorbers. I think that any company that feels the need to trade under about a dozen different names or uses a UK sounding company name and a .co.uk website address and imply quick delivery and hide the fact that they are in Berlin unless you read the tiny print and not the sort of company I want to deal with....so I don't anymore. 1.7 on Trustpilot does less than fill me full of confidence too! YMMV
Review – AutoDoc - My Honest Experience
A good independent motor factor is a joy, but with so few left I've had to turn to AutoDoc for elusive French servicing parts. This is my experience, and 'Top 5 Tips' for happy AutoDoc'ing.bxproject.co.ukAUTODOC - Great Britain is rated "Great" with 4.1 / 5 on Trustpilot
Do you agree with AUTODOC - Great Britain's TrustScore? Voice your opinion today and hear what 10,948 customers have already said.uk.trustpilot.com
