E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
I changed the whole fog lamp unit on the E300TD last winter after a stone broke it.
I accessed it from underneath at the rear of the lamp unit.
If you are only changing the bulb, the access is also from the back.
I changed the whole fog light unit on the E300TD last winter after a stone broke it.
Depending on the type of fog-light fitted, you may find that you can just purchase the glass from MB.....i did this on my c-class and it cost me about £10......much cheaper than purchasing the whole unit.
Was simple to change too, if a bit fiddly.....helps if you remove the front wheel too to get access (at least it did on a c-class)
On the facelift w210 (which yours is) there is a small trap door under the bumper, below the fog light. Reach in remove the cover from the back of the fog light, remove bulb and replace.
