Hi, how do you remove the front side light. I was intended to replace with a w5w light bulbs and thought it was a case of just pulling it out.
The car is UK spec. I've taken a photo below. Its the bulb at the bottom, as you can see from the front of the head lights, it doesn't look like bulb, looks more like an extended lens.
Any advice or how to links appreciated.
