DoctorMesmer
My 2015 S212 has a problem with water poooling in the front nearside wing (between the door and the wheel) after I wash it.
I reported this to MB who said the drain hole was clear but said there may be a blockage further up that's stopping the water draining properly. However, they "ran out of time" when it was booked in and didn't complete the job (yes, really).
What they said would tie in with my own observations that when I push in the wheel arch liner slightly, the water drains – as if there's a blockage further up that's creating a vacuum and holding the water in. I've cleared around the drain hole at the top of the wing near the bonnet mounts and it's as clean as a whistle, so it obviously not there.
Where is this likely to be and can I easily clear it myself?
Thanks in advance for any suggestions.
