FS: SnapOn Diagnostic Scanner - FULL KIT & ACCESSORIES!
GSMGuy
St Helens, Merseyside
Volvo XC90 D5 SE
Due to upgrading, I am selling my trusty SnapOn MT2500 Diagnostic Scanner
Much more than a generic code reader, it also does "activations" so allows you to test operation of relays, valves modules and more - also does things like code TDCi injectors, and much more.
Comes with Vehicle Specific software for the following makes;
Ford V6.3
Opel/Vauxhall V6.7 (also covers Movano, Arena & Vivaro)
Renault V4.1
VAG V6.1 (Audi, Seat, Skoda & VW)
Also FULL EOBD for all vehicles V4.8
Because this comes with the later PVCI cartridge, it is FULLY upgradeable by SnapOn, or you can buy an ALL MAKES PVCI cart on Ebay for approx £200.
It is also fully CAN-BUS compatible with the (£25 Ebay) Adaptor
TBH, you only need vehicle specific if you specialise in those cars, as it allows you to test and interrogate EVERY module on that specific vehicle.
Comes with the following leads/adaptors
DL-16 (OBD) for ALL later vehicles
Data Cable
Following leads for older/spurious cars:
PSA-2 (Peugeot, Citroen Fiat)
ROV-1 (Rover)
VW-1 (Pre OBD)
Skoda-1A
REN-2 (Non OBD Renault)
Vaux/Opel-2 (Non OBD Vaux/Opel)
PSA-1 (Other PSA connector)
Ford-3 (Older ABC plugs)
Power adaptors for battery and cigar lighter
So that you can use the same OBD lead on all vehicles, rather than mess around with jumpers and pins, the SnapOn system uses "Personality Keys" which configure the lead for a particular vehicle by simply plugging the correct key.
Comes with the following keys: S-2A, S-4, S-7, S-11, S-25, S-26, S-27, S-28, S-32, S-33, S34 & S-40
Has cost me well over £2200 with the keys, leads and recent software updates, it is running V2.2 software, not the older v1.8 that a lot on ebay have..
Comes in SnapOn Case and has made & saved me a LOT of money...
£375 collected or delivery by courier for £15?
The bare bodies alone go for £150 with no leads, software or keys!
This is AS NEW and the DL-16 lead is only a month or so old, (£50) from SnapOn
Mike
Would also do a swap/trade on this for a Canon Digital SLR with adjustment either way if required...
Mike
