jenmercclk
- Sep 25, 2009
Anyone know how to remove the petrol filler flap lock on a 2001 CLK200 coupe? There's a plastic housing in the filler cavity with a rubber grommet but not sure if this twists, pulls off or what and don't wanna break it. Can't seem to remove it from inside the boot either. There is a problem with that lock releasing very slowly which in turn is causing boot lock to take ages to release. The vac pump has to run for 15 or so seconds in order to open the filler and the boot before it "times-out", so useful to get to the filler actuator etc to check for air leak. Boot lock has no air leak. This is listed under "Electronics" also.
