Fuel gauge playing up - W208 CLK55 AMG
Discussion in 'Engine' started by MiG, Dec 8, 2008.
  1. MiG
    MiG New Member
    27
    Dec 6, 2008
    Does anyone else have a problem with their fuel gauge? When this is filled right up it all sorts of confusion follows - reading full, empty and everything in between for the first half of the tank and then seems to right itself.
    I now estimate how much fuel I need to fill the tank and put it in a little less and the gauge behaves itself...
  2. mr. shr
    mr. shr Hardcore MB Enthusiast
    1,879
    Apr 22, 2004
    The fuel gauge on my old W208 wasn't very reliable but then I don't think they are on any Merc.
    On my W202, the needle will move just a couple of mm for the first 100 miles and then down to half a tank for the next 100 miles.
    With both my cars, I always reset the milage each time I fill up, so I know how far I've gone on the current tank. When I hit 300 miles, I know it's time to consider filling up.
  3. W210 Fan
    W210 Fan Hardcore MB Enthusiast
    1,434
    Nov 16, 2005
    Godalming
    Car:
    W140 S500L W208 430
    Thats because some mercs have a wedge shaped tank with the shallow end at the bottom so the top takes ages and the bottom goes quicker,
  4. rajinder_1
    rajinder_1 Hardcore MB Enthusiast
    983
    Jan 30, 2006
    Midlands
    Car:
    01' Designo SL320 , 96' C36 AMG, 98' C43 AMG Estate 19' Focus & 96' ZX6R Ninja
    As for dodgy readings i have found that i never get it from Texaco Fuel, or i use Forte Gas Treatment every so often and fill up which normally clears it up....
    i had it with both the SL and the C Class
    Raj
  5. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,801
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    Use some fuel system cleaner and your problem will be sorted.
  6. Scorcher
    Scorcher Hardcore MB Enthusiast
    203
    Mar 26, 2008
    South Croydon
    Car:
    2004 E55 AMG
    My E55 went back to MB for a faulty keyless entry sensor, and while it was in they carries out a recall repair / replacement on the fuel sensor.
    Wonder if it applies to all 55K engines?
  7. OP
    OP
    MiG
    MiG New Member
    27
    Dec 6, 2008
    Thanks Scorcher. Will check that out after I've tried some fuel cleaner if it doesn't fix it.
    Great wheels BTW - did you adapt those from standard? I have a snow white car and was thinking about getting the wheels done in black.
  8. Scorcher
    203
    Mar 26, 2008
    South Croydon
    Car:
    2004 E55 AMG
    Nope - they came this way from AMG :)
  9. skemball
    skemball Hardcore MB Enthusiast
    129
    Aug 8, 2005
    Berkshire
    Car:
    E320 CDi
    If the fuel level sender unit in the tank uses a conventional rheostat (resistor) type of design it implies that it might be worn/damaged/contaminated at the full-tank end, hence erratic reading. If this is the design it works on the principle of a metal contact arm that wipes across the variable resistor as the fuel level varies.
  10. OP
    OP
    MiG
    MiG New Member
    27
    Dec 6, 2008
    That would explain it... Got some fuel cleaner in there at the moment. If that doesn't shift the problem, may just leave it as I can avoid the problem by not overfilling the tank (up to the cut off point at the pump). Very strange phenomenon.
Share This Page
