B160 Petrol
Hi guys,
I have a Mercedes B Class W245 CVT Petrol 2010 plate.
I’ve been getting bad fuel economy, I’ve tried a number of things to improve it, I’m getting around 19MPG city driving.
I have had my mechanic to change the fuel injectors. I purchased 4 New Bosch injectors. I was hoping that this will solve my MPG problem, however, it hasn’t. Do I need to get the ECU reset for the new injectors? If so how can I do this?
On another note the car also has a slight air suction from the engine bay when I tap the accelerator, it sounds like it’s coming from the air filter box which is joint to the throttle body. All pipes and hoses have been check and there are no vacuum leaks(according to mechanic).
Thank you in advance for looking at my post.
