Hello fellow forum-ers
I am after some advice again if possible. I have a fuel leak on my 108cdi i have already done a kitchen roll wrap test and dismissed the injectors as the faulty area. I noticed it when I changed a screaming ancillary belt which by the looks of it was because of the diesel on it. The problem is the leak has been hitting the belt and throwing it all over the place which has made it almost impossible to trace. The mechanic at work has had a brief look and has pointed out it must be below the fuel filter somewhere as its dry on the top and above it. He said there are a couple of pipes that run to the fuel pump from the bottom of the filter housing and it was probably one of them but he has said he is not an expert on merc but suggested that I remove the headlight grill and air box and then block the engine and remove the engine mount to get better access to try to isolate the leak and then repair it. This seems a bit OTT for a fuel leak and wondered if there are any easier ways to find it or if there is anything that is quite a common failure point. The engine is running fine but with a slight diesel knock and starts on the button and is still getting 35ish mpg. Any ideas..???
Thanks in advance
Thanks in advance
