I am currently trying to find out what could be causing my ML 270's engine to emit steam when idle in traffic etc.
I have a fuel leak..and a little oil leak I have been advised. I have had 3 garages look into this. 2 have said injector 1 is goosed (bodge job) and the 3rd - the garage I purchased from said they replaced said injector and the bodge work was bad prior to them getting it. (Dont worry I know that's naughty of them to sell a car like this and I will use this to my advantage)
The car runs well? 400+ miles to a tank and I only notice the steam when stopped. Couple of pointers.....now I have replaced the thermostat, and the right side coolant temp switch.I took it back to the garage I purchased from (140 mile round trip!) for them to check out the fuel leak . They sprayed the injectors and none where showing signs of leaking when running idle and I can't recall the steam showing as bonnet was up.
Its smells like fuel said qualified mechanic????? But it is getting worse. Engine is not overheating, in fact sits at a perfect 87 ish.
Could it be a fuel leaking elsewhere. Could all of the tar on the injectors, the back of the engine cover (long mercedes one) that when heating up emit steam vapours or coolant leak as a cause. I did top up using a normal 50/50 coolant do I need a special one?
Thanks in advance.
Thanks in advance.
