Fuel pressure to low bank one error
Discussion in 'Engine' started by Vinnycarr666, Feb 15, 2020.
  1. Vinnycarr666
    Vinnycarr666 New Member
    1
    Feb 15, 2020
    Skegness
    Car:
    Mercedes e270
    I have a Mercedes e270 and changed the injector seals on 1 and 3 now not firing. Getting error on diagnostics fuel pressure too low bank 1. How do I build the pressure back up, I have got fuel up to the injectors with no air, just turning over but not firing
  2. mersum1es
    mersum1es Hardcore MB Enthusiast
    1,253
    Aug 9, 2012
    Finland
    Car:
    W219, W220
    Which car, W210 and W211 270CDI has different fuel systems...
    Applies both; Check all injector conenctors (pins withdraw easily), then you can top up your fuel filter, load battery full crank crank...
Share This Page
