Fuel problem with c250 td 1997
eve123
mercedes
Can anybody help? I have just changed the engine in my c250 td 1997 estate and can't get fuel to the injectors, getting fuel up to the injector pump but not out the injector pump.
Any suggestions?
Thanks.
Are you sure the feed through the lift pump is the correct way round. After that it needs electricity at the high pressure pump and it should go.
I have the same problem with my TD c250 Mercedes it seems that the electrical signals doesn't come or it comes but there is something stuck in the high pressure pump. some body help
