Druk
Gone but not forgotten - RIP
- May 28, 2004
- Location
- Not far from Edinburgh.
- 2011 S212 E350CDi. 1981 R107 300TurboDiesel.
Fired up the 107 after it's winter hibernation and after an initial easy start, it cut out. Traced it to a seized fuel pump. Replaced (temporarily?) with one from the tandem dual pump setup off a deceased W124 320e. This is a smaller dia pump from the standard. Car started easily and seems to run fine although haven't as yet had it out on the motorway at sustained speed. (K-jetronic injection)
Q? Is there a different pressure and/or flow from the smaller pump and will I damage something using it long term? I've got two of them and it would be a waste to go spend £200 on the correct item when not required.
