Fuel pump problem
XanderLorenzo
United States
Benz
I have a 1994 E320 sedan and a while back the car would feel like it would lose power randomly while driving as if my foot left the gas pedal then one day I parked it and the car didn’t start, it had to be towed home. Turns out The car will not turn the fuel pumps on when the key is turned on. After that I started the search for the problem, replacing the fuel pumps first then the green relay next to the battery then the OVP relay and that solved a few problems but not the fuel pumps. What I have to do to make the car work is jump the pins on the green fuel pump relay next to the battery with a wire. Anyone else know what I can do that would help the car work better?
