finisterre
hi
my old vito 638 is playing me for a fool - MOT fail on offside full beam
-if I put the headlights on and choose full beam the nearside light is fine and the offside is not working
first I tried four bulbs then tested them on the nearside. no progress.
I checked the earth - it made no difference when I linked the brown wire to the chassis.
Next, fuses, positions 2&3 under the steering wheel - sound, swapped them anyway and the problem persisted
okay- voltmeter across the terminals in the disconnected connector block, 11.98v switched to full beam on both sides between earth and the orange wire. They should be working then.
swapped the bulbs again, getting desperate. -no progress.
cleaned the terminals- no progress
checked the voltage between the terminals with a working bulb inserted - 0 volts. grrr
What is the problem? It is baffling me.
suggestions welcome...
