Full Diagnostic Trouble Codes List
Looking through the threads... and cant see too much about Code P0130 . can anyone point me of my first point of call to check, 02 sensor, Bank 1 sensor 1 .. Ive got 2006 CLK 200K (A209)
any helpful comments appreciated.. cheers
Marti
Marti
Hi Marti, here is a list and explanation of OBD fault code's,,,,,I got it some time ago from a post by Chris A...( hope you don't mind Chris?? )
Good Luck Marti, and let us know how you get on, OK? Thanks.
Hi, Thanks all for looking at my thread, so questions for anyone familiar with the M271 engine.. It turns out I am getting no data feedback from the pre cat sensor, its a new bosh exact match fitted, Ive also cleaned as much as possible with contact cleaner the ecu, all connectors and hopefully into the loom also as advised replaced the oil seals in the egr cam magnets, but it is still coming up with code P0030 which is fault in the circuit with bank 1 sensor 1 ... wat would be my next step to solve this ? attached picture is my reading of my O2 sensors ... pre cat no data ... post cat working good.. where do I go from here...
TIA,
Marti.
hi got three codes from my machine
po471 p1408 mentions koer , p2a00
The diagnostic fault codes posted on the first couple of pages refer to the readout from MB Star diagnostics.
You have a generic code reader and need to Google the fault codes for that specific reader.
This is so useful! Thanks
I see now only trucks and bus. But I found promo codes.
PFZXZTNXE60CT987H61765B
CS1BEG0EGQNA7EHFMBXALX9
So just copy and paste into Google search bar?
P04XX Auxiliary Emission Controls
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor “A” Circuit Low
P0406 Exhaust Gas Recirculation Sensor “A” Circuit High
P0407 Exhaust Gas Recirculation Sensor “B” Circuit Low
P0408 Exhaust Gas Recirculation Sensor “B” Circuit High
P0409 Exhaust Gas Recirculation Sensor “A” Circuit
P0410 Secondary Air Injection System
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve “A” Circuit
P0413 Secondary Air Injection System Switching Valve “A” Circuit Open
P0414 Secondary Air Injection System Switching Valve “A” Circuit Shorted
P0415 Secondary Air Injection System Switching Valve “B” Circuit
P0416 Secondary Air Injection System Switching Valve “B’ Circuit Open
P0417 Secondary Air Injection System Switching Valve “B” Circuit Shorted
P0416 Secondary Air Injection System Relay “A” Circuit
P0419 Secondary Air injection System Relay “B” Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit (Bank 2)
P0440 Evaporative Emission Control System
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission Control System Pressure Sensor
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P0457 Evaporative Emission Control System Leak Detected (fuel cap loose/off)
P0460 Fuel Level Sensor Circuit
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 EVAP Purge Flow Sensor Circuit
P0466 EVAP Purge Flow Sensor Circuit Range/Performance
P0467 EVAP Purge Flow Sensor Circuit Low Input
P0468 EVAP Purge Flow Sensor Circuit High Input
P0469 EVAP Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit
P0481 Cooling Fan 2 Control Circuit
P0482 Cooling Fan 3 Control Circuit
P0483 Cooling Fan Rationality Check
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit
P0486 Exhaust Gas Recirculation Sensor “B” Circuit
P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
P0491 Secondary Air Injection System (Bank 1)
P0492 Secondary Air Injection System (Bank 2)
P05XX Vehicle Speed, Idle Control, and Auxiliary Inputs
P0500 Vehicle Speed Sensor
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0508 Idle Control System Circuit Low
P0509 Idle Control System Circuit High
P0510 Closed Throttle Position Switch
P0512 Starter Request Circuit
P0513 Incorrect Irnmobilizer Key (“Immobilizer pending SAE J1930 approval)
P0515 Battery Temperature Sensor Circuit
P0516 Battery Temperature Sensor Circuit Low
P0517 Battery Temperature Sensor Circuit High
P0520 Engine Oil Pressure Sensor/Switch Circuit
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0524 Engine Oil Pressure Too Low
P0530 A/C Refrigerant Pressure Sensor Circuit
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0540 Intake Air Heater Circuit
P0541 Intake Air Heater Circuit Low
P0542 Intake Air Heater Circuit High
P0544 Exhaust Gas Temperature Sensor Circuit (Bank 1)
P0545 Exhaust Gas Temperature Sensor Circuit Low (Bank 1)
P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1)
P0547 Exhaust Gas Temperature Sensor Circuit (Bank 2)
P0548 Exhaust Gas Temperature Sensor Circuit Low (Bank 2)
P0549 Exhaust Gas Temperature Sensor Circuit High (Bank 2)
P0550 Power Steering Pressure Sensor Circuit
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0564 Cruise Control Multi-Function Input Signal
P0565 Cruise Control On Signal
P0566 Cruise Control Off Signal
P0567 Cruise Control Resume Signal
P0568 Cruise Control Set Signal
P0569 Cruise Control Coast Signal
P0570 Cruise Control Accel Signal
P0571 Cruise Control/Brake Switch A Circuit
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Cruise Control Input Circuit
P0576 Cruise Control Input Circuit Low
P0577 Cruise Control input Circuit High
P0578 through P0580 Reserved for Cruise Control Codes
P06XX Computer and Auxiliary Inputs
P0600 Serial Communication Link
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 ECM/PCM Processor
P0607 Control Module Performance
P0608 Control Module VSS Output “A”
P0609 Control Module VSS Output “B”
P0610 Control Module Vehicle Options Error
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0618 Alternative Fuel Control Module KAM Error
P0619 Alternative Fuel Control Module RAM/ROM Error
P0620 Generator Control Circuit
P0621 Generator Lamp “L” Terminal Control Circuit
P0622 Generator Field “F” Terminal Control Circuit
P0623 Generator Lamp Control Circuit
P0624 Fuel Cap Lamp Control Circuit
P0630 VIN Not Programmed or Mismatch - ECM/PCM
P0631 VIN Not Programmed or Mismatch - TCM
P0635 Power Steering Control Circuit
P0836 Power Steering Control Circuit Low
P0637 Power Steering Control Circuit High
P0638 Throttle Actuator Control Range/Performance (Bank 1)
P0639 Throttle Actuator Control Range/Performance (Bank 2)
P0640 Intake Air Heater Control Circuit
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Control Circuit Low
P0647 A/C Clutch Relay Control Circuit High
P0648 Immobilizer Lamp Control Circuit (“Immobilizer” pending SAE J1930 approval)
P0649 Speed Control Lamp Control Circuit
P0650 Malfunction Indicator Lamp (ML) Control Circuit
P0654 Engine RPM Output Circuit
P0655 Engine Hot Lamp Output Control Circuit
P0656 Fuel Level Output Circuit
P0660 Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
P0663 Intake Manifold Tuning Valve Control Circuit (Bank 2)
P0664 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
P0665 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
P07XX Transmission
P0700 Transmission Control System (MIL Request)
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Switch In put Circuit Malfunction
P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0739 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Circuit
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid “A”
P0746 Pressure Control Solenoid “A” Performance or Stuck Off
P0747 Pressure Control Solenoid “A” Stuck On
P0748 Pressure Control Solenoid “A” Electrical
P0749 Pressure Control Solenoid “A” Intermittent
P0750 Shift Solenoid “A”
P0751 Shift Solenoid “A” Performance or Stuck Off
P0752 Shift Solenoid “A” Stuck On
P0753 Shift Solenoid “A” Electrical
P0754 Shift Solenoid “A” Intermittent
P0765 Shift Solenoid “B”
P0756 Shift Solenoid “B” Performance or Stuck Off
P0757 Shift Solenoid “B” Stuck On
P0758 Shift Solenoid “B” Electrical
P0759 Shift Solenoid “B” Intermittent
P0760 Shift Solenoid “C”
P0761 Shift Solenoid “C” Performance or Stuck Off
P0762 Shift Solenoid “C” Stuck On
P0763 Shift Solenoid “C” Electrical
P0764 Shift Solenoid “C” Intermittent
P0765 Shift Solenoid “C”
P0766 Shift Solenoid “D” Performance or Stuck Off
P0767 Shift Solenoid “D” Stuck On
P0768 Shift Solenoid “D” Electrical
P0769 Shift Solenoid “D” Intermittent
P0770 Shift Solenoid “E”
P0771 Shift Solenoid “E” Performance or Stuck Off
P0772 Shift Solenoid “E” Stuck On
P0773 Shift Solenoid “E” Electrical
P0774 Shift Solenoid “E” Intermittent
P0775 Pressure Control Solenoid “B”
P0776 Pressure Control Solenoid “B” Performance or Stuck Off
P0777 Pressure Control Solenoid “B” Stuck On
P0778 Pressure Control Solenoid “B” Electrical
P0779 Pressure Control Solenoid “B” Intermittent
P0780 Shift
P0781 1-2 Shift
P0782 2-3 Shift
P0783 3-4 Shift
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
P0791 Intermediate Shaft Speed Sensor Circuit
P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor Circuit No Signal
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
P0795 Pressure Control Solenoid “C”
P0796 Pressure Control Solenoid “C” Performance or Stuck off
P0797 Pressure Control Solenoid “C” Stuck On
P0798 Pressure Control Solenoid “C” Electrical
P0799 Pressure Control Solenoid “C” Intermittent
P08XX Transmission
P0801 Reverse Inhibit Control Circuit
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit
P0805 Clutch Position Sensor Circuit
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0820 Gear Lever X-Y Position Sensor Circuit
P0821 Gear Lever X Position Circuit
P0822 Gear Lever Y Position Circuit
P0823 Gear Lever X Position Circuit Intermittent
P0824 Gear Lever Y Position Circuit Intermittent
P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
P0830 Clutch Pedal Switch “A” Circuit
P0831 Clutch Pedal Switch “A” Circuit Low
P0832 Clutch Pedal Switch “A” Circuit High
P0833 Clutch Pedal Switch “B” Circuit
P0834 Clutch Pedal Switch “B” Circuit Low
P0835 Clutch Pedal Switch “B” Circuit High
P0836 Four Wheel Drive (4WD) Switch Circuit
P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P0840 Transmission Fluid Pressure Sensor/Switch “A” Circuit
P0841 Transmission Fluid Pressure Sensor/Switch “A” Circuit Range/Performance
P0842 Transmission Fluid Pressure Sensor/Switch “A” Circuit Low
P0843 Transmission Fluid Pressure Sensor/Switch “A” Circuit High
P0844 Transmission Fluid Pressure Sensor/Switch “A” Circuit Intermittent
OBD 2 Fault Codes Reference Guide
P0845 Transmission Fluid Pressure Sensor/Switch “B” Circuit
P0846 Transmission Fluid Pressure Sensor/Switch “B” Circuit Range/Performance
P0847 Transmission Fluid Pressure Sensor/Switch “B” Circuit Low
P0848 Transmission Fluid Pressure Sensor/Switch “B” Circuit High
P0849 Transmission Fluid Pressure Sensor/Switch “B” Circuit Intermittent
P09XX Transmission
P1XXX Manufacturer Controlled
P10XX Fuel and Air Metering and Auxiliary Emission Controls
P11XX Fuel and Air Metering
P12XX Fuel and Air Metering
P13XX Ignition System or Misfire
P14XX Auxiliary Emission Controls
P15XX Vehicle Speed, Idle Control, and Auxiliary Inputs
P16XX Computer and Auxiliary Outputs
P17XX Transmission
P18XX Transmission
P19XX Transmission
P2XXX SAE Controlled DTCs
P20XX Fuel and Air Metering and Auxiliary Emission Controls
P21XX Fuel and Air Metering and Auxiliary Emission Controls
P22XX Fuel and Air Metering and Auxiliary Emission Controls
P23XX Ignition System or Misfire
P3XX Manufacturer Controlled and SAE Reserved
P30XX Fuel and Air Metering and Auxiliary Emission Controls
P31XX Fuel and Air Metering and Auxiliary Emission Controls
P32XX Fuel and Air Metering and Auxiliary Emission Controls
P33XX Ignition System Misfire
That’s a fantastic document. Many thanks for publishing it in full
P2200 Component Y3/6n2(speed sensor 2) is faulty or the sensor supply has Short circuit.
P2200 Instrument cluster Fault from instrument cluster over CAN
P2200 Instrument cluster Preglow indicator lamp faulty
P2201 CAN message from control module DAS Plausibility 1
P2201 CAN message from control module DAS Plausibility 2
P2201 CAN message from control module DAS:CAN signal faulty
P2201 No or incorrect CAN message from control unit DAS
P2202 External quantity control by DTR control module Not all CAN messages have been received.
P2202 External quantity control by DTR control module Request from control module N63/1 (DTR control module) is implausible.
P2202 External quantity control by DTR control module The CAN message is implausible
P2202 External quantity control by DTR control module Torque request from control module N63/1 (DTR control module) is faulty.
P2203 Component Y3/6n3 (speed sensor 3) is faulty.
P2203 External quantity control by ESP NO COMMUNICATION
P2203 External quantity control by ESP Not all CAN message have been received.
P2203 External quantity control by ESP Request from control module ESP is implausible.1
P2203 External quantity control by ESP Request from control module ESP is implausible.2
P2203 External quantity control by ESP The CAN message is implausible.
P2203 External quantity control by ESP Torque request from control module ESP is faulty.
P2203 The internal electrical check of Component Y3/6n3(speed sensor 3) has failed.
P2204 External quantity control by ETC CAN reception timeout
P2204 External quantity control by ETC ENGINE STOP
P2204 External quantity control by ETC Not all CAN messages have been received.
P2204 External quantity control by ETC Read fault memory of control unit N15/3 (ETC control module).
P2204 External quantity control by ETC Read fault memory of control unit Transmission control.
P2204 External quantity control by ETC Request from control module N15/3 (ETC control module) is implausible.
P2204 External quantity control by ETC The CAN message is implausible.
P2204 External quantity control by ETC Torque request from control module N15/3 (ETC control module) is faulty.
P2206 No signal from output speed sensor
P2207 The value of component Y3/6n3 (speed sensor 3) is implausible.
P220A The speed comparison of Y3/6n2 or Y3/6n3 is implausible.
P220B The speed of Y3/6n2 or Y3/6n3 is too high.
P2210 Selector lever coding is invalid.
P2211 The selector lever is in an intermediate position.
P2212 The selector lever position is implausible.
P2220 Component Y3/6s1(Starter lockout contact) or component Y3/6b1 (ATF temperature sensor) is faulty or both.
P2221 The signal of component Y3/6b1 (ATF temperature sensor) and (or) Y3/6s1 (Starter lockout contact) is implausible.
P2222 The signal of component Y3/6b1 (ATF temperature sensor) and (or) Y3/6s1 (Starter lockout contact) is implausible.
P2300 CAN communication is faulty.
P2300 CAN communication with other control units installed in this vehicle is not possible.
P2301 CAN communication is faulty.
P2301 CAN communication with other control units installed in this vehicle is not possible.
P2306 N3/9 (CDI control module) Sensor supply voltage 2 Readout too large
P2306 N3/9 (CDI control module) Sensor supply voltage 2 Readout too small
P2310 CAN communication with the traction system is faulty.
P2310 One or more messages from control unit N47(Traction systems control module) are not available on the CAN bus.
P2311 CAN communication with the engine system is faulty.
P2311 One or more messages from the engine control unit are not available on the CAN bus.
P2312 CAN communication with the engine system is faulty or engine temperature is implausible.
P2312 One or more messages from the engine control unit are not available on the CAN bus.
P2313 There is a fault in CAN communication with control module N15/5 (electronic selector lever module control module) or the selector lever position of control module ESM is implausible.
P2314 Fault in CAN communication with control unit N73 (EIS control module)
P2314 One or more messages from control unit N73(EIS control module) are not available on the CAN bus.
P2315 Fault in CAN communication with control unit A1 (Instrument cluster)
P2315 One or more messages from control unit A1(Instrument cluster) are not available on the CAN bus.
P2316 Fault in CAN communication with control unit A1 (Instrument cluster)
P2316 One or more messages from control unit N19(Air conditioning control module) are not available on the CAN bus.
P2317 One or more messages from control unit N78(Transfer case control module) are not available on the CAN bus.
P2317 There is a sporadic fault in CAN communication with control module N78 (Transfer case control module) or the transfer case position is sporadically implausible.
P2318 Fault in CAN communication with control unit N15/5 (electronic selector lever module control module)
P2318 One or more messages from control unit N15/5(electronic selector lever module control module) are not available on the CAN bus.
P2319 Analogue-digital converter Dynamic RAM test is incorrect.
P2319 Analogue-digital converter Ground keying of pedal value sensor PWG2 is incorrect.
P2319 Analogue-digital converter Test voltage is incorrect.
P2330 The CAN signal from traction system is faulty.
P2330 The CAN signals sent from control unit N47(Traction systems control module) are incomplete.
P2331 The CAN signal from the engine system is faulty.
P2331 The CAN signals sent from control unit Engine management are incomplete.
P2332 The CAN signal from the engine system is faulty.
P2332 The CAN signals sent from control unit Engine management are incomplete.
P2333 The CAN signal from control module N15/5 (electronic selector module control module) is faulty.
P2333 The CAN signals sent from control unit N15/5(electronic selector module control module) are incomplete.
P2334 The CAN signal from control module N73 (EIS control module) is faulty.
P2334 The CAN signals sent from control unit N73(EIS control module) are incomplete.
P2335 The CAN signal from control module A1 (Instrument cluster) is faulty.
P2335 The CAN signals sent from control module A1(Instrument cluster) are incomplete.
P2336 The CAN signal from control module N73 (EIS control module) and (or) A1 (Instrument cluster) is faulty.
P2336 The CAN signal from control module N73(EIS control module) and (or) A1 (Instrument cluster) is faulty.
P2337 The CAN signal from control module N78 (Transfer case control module) is faulty.
P2337 The CAN signals sent from control unit N78(Transfer case control module) are incomplete.
P2338 The CAN signal from control module N15/5 (electronic selector lever module control module) is faulty.
P2338 The CAN signals sent from control unit N15/5(electronic selector lever module control module) are incomplete.
P2400 The rear right wheel speed of the traction system is implausible.
P2400 The right rear wheel rpm signal sent from the traction system via the CAN bus is implausible.
P2401 The left rear wheel rpm signal sent from the traction system via the CAN bus is implausible.
P2401 The rear left wheel speed of the traction system is implausible.
P2402 The front right wheel speed of the traction system is implausible.
P2402 The right front wheel rpm signal sent from the traction system via the CAN bus is implausible.
P2403 The front left wheel speed of the traction system is implausible.
P2403 The left front wheel rpm signal sent from the traction system via the CAN bus is implausible.
P2404 The CAN signal from component S9/1 (Stop lamp switch) of the traction system is implausible.
P2404 The stop lamp switch signal sent from the traction system via the CAN bus is implausible.
P2405 The accelerator pedal value of the engine system is implausible.
P2405 The accelerator pedal value sent from the engine control unit via the CAN bus is implausible.
P2406 The engine torque from the engine system is implausible.
P2406 The specified static torque sent from the engine control unit via the CAN bus is implausible.
P2407 The default torque of the traction system is implausible.
P2407 The engine torque specified by the traction system and sent from the engine control unit via the CAN bus is implausible.
P2408 The engine torque from the engine system is implausible.
P2408 The maximum engine torque sent from the engine control unit via the CAN bus is implausible.
P2409 The engine torque from the engine system is implausible.
P2409 The maximum engine torque sent from the engine control unit via the CAN bus is implausible.
P240A The engine speed of the engine system is implausible.
P240A The engine speed sent from the engine control unit via the CAN bus is implausible.
P240B The engine speed sent from the engine control unit via the CAN bus is implausible.
P240B The engine temperature from the engine system is implausible.
P240C The CAN signal for the selector lever position from component N15/5 (electronic selector lever module control module) is implausible.
P240C The selector lever position sent from control unit N15/5(electronic selector Lever module control module)via the CAN bus is implausible.
P240D The current transfer case sent from control unit N78(Transfer case control module) via the CAN bus is implausible.
P240D There is a sporadic fault in CAN communication with control module N78 (Transfer case control module) or the transfer case position is sporadically implausible.
P2500 The transmission has an impermissible transmission ratio.
P2501 Engine overevving has occurred.
P2502 The gear is implausible or the transmission is slipping.
P2503 The gear comparison is negative or the target gear is not reached.
P2510 The torque converter lock-up clutch causes impermissible closing.
P2511 Engaging of torque converter lockup clutch not permitted.
P2511 The torque converter lock-up clutch has excessive power consumption.
P2512 Actuation of torque converter lockup clutch is not possible
P2520 The feedback through the transmission protection is not maintained.
P2600 The voltage supply of circuit 87 has undervoltage.
P2601 The voltage supply of circuit 87 has overvoltage.
P2602 The voltage supply of the valves is faulty.
P2603 The voltage supply of the speed sensors is faulty.
Hi
I have and sbs and an esp fault telling me to visit workshop. The car remains faulty- is that because the faults haven’t been cleared? And I have to clear them because the errors are related to safety
Any advice is appreciated
Wow O2 sensor cost
I need a down stream o2 sensor. Mercedes’ main dealer quote ££266.40.
Euro parts quote £56 for a Bosch sensor
Does anyone know if the OEM sensor is made by Bosch. The parts why at Main dealer couldn’t or wouldn’t tell me
icarsoft Problem.
I have an R171 SLK350 and a C180K estate. icarsoft (i980) gives me the full range of scanning options for the SLK including the engine. The C180 covers everything but the engine, nothing appears on the list for this. I have tried upgrading it but when I input the serial number it says invalid number.
Any ideas? Thanks. Dave
