fumes in carc200 cdi, 2003
carlfish
hi all started to get exhaust fumes in car seems to become from the heater anybody had this happen , can it be the injector seals or cabin filter thanks carl
If its a fuel leak it will smell like diesel. If its stinging your eyes then injector seals I would imagine.
Press the air recirc button on the climate control panel when you drive, as this will filter the fumes much better.
Any fumes are bad so get it sorted ASAP
its exhaust fumes not diesel are injector seals common to leak , will order some tomorrow can anybody point me in the right place to get the torque setting for the injector bolts thanks carl
Yes injector seals do commonly leak
IIRC the torque is 7NM + 90deg + 90deg turns
Thanks all will order seals tomorrow
