neiledgar
Ok Guys im really stumped now, i have all front suspension arms fitted to my car, two track rod ends and the drag links, the steering was all over the place so with advice from club members i had the car set up with the 4 wheel hunter system, the steering was still snatching on corners and wavering on straights, so one assumed that i had to have the steering angle sensor re-set to perfect alignment.
Duly done on a snap on machine, i think it was solus?? not sure of spelling but a professional machine anyway. The guy set everything up and went on road test as the system told us to,anyway, im left with the following, the steering it still bad, ive no ABS, the BAS light is on and the ESP light is on and working away under the bonnet, i have two codes as well, the first is C1410, says road test active, then the code C1600 it says on the machine, electronic stability program (ESP), speed sensetive power steering (SPS) and brake assist system (BAS) ECU- N47-5 coding is faulty, can anyone help me please, the car was running spot on before any works started, then the works above were done, and now the car is all over the place, im disabled and reply on the car, im lost without it im scared to use it as steering is wild, it keeps trying to grab it out of my hands on corners. Has anyone got any ideas, how i can rectify the problems?? Thanks Guys:
