Fuse Layouts
Discussion in 'Electronics' started by CiaranMcKeown, Aug 8, 2008.
  1. CiaranMcKeown
    CiaranMcKeown Active Member
    226
    Sep 11, 2007
    Belfast
    Car:
    C220 CDI Black
    Where could i get a sort of map of the fuses of my 02 w203, i have no handbook. The fuse im looking for is actually the ciggy lighter fuse, i think its blown because my phone charger aint working anymore in my car.
  2. SilverSaloon
    SilverSaloon MB Enthusiast
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    there may be a piece of card inside the lid of your fusebox telling you what fuse does what.
    alternatively, just look in the fusebox for a blown fuse and replace!
  3. OP
    OP
    CiaranMcKeown
    226
    Sep 11, 2007
    Belfast
    Car:
    C220 CDI Black
    are there any hidden ones i dont know about... i know theres one in the boot, besdie the steering wheel and under the bonnet, is there one anywhere else?
    I dont mind going through each one, but then i dont know if the correct amp fuse is in it.
  4. Chattonmill
    Chattonmill MB Enthusiast
    1,498
    Mar 20, 2008
    Northumberland
    Car:
    S211 E55 AMG
    Have you tried the fuse in the phone charger?......Just a thought
  5. OP
    OP
    CiaranMcKeown
    226
    Sep 11, 2007
    Belfast
    Car:
    C220 CDI Black
    yea, tried the charger in another car, works fine.
    Is there nowhere i can find a layout of the fuses?
  6. SilverSaloon
    7,759
    Mar 16, 2004
    Car:
    probably very likely a 15A fuse. Also very likley to be in the engine bay
  7. Diesel Benz
    Diesel Benz MB Enthusiast
    4,086
    Feb 3, 2006
    Europe
    Car:
    222.132 & 221.122 & 213.050 & 906.633
    Yes, fuse number 47, engine compartment fuse box, 15A. Should source the glove compartment light too.
  8. rlowy
    rlowy Active Member
    305
    Apr 14, 2007
    Surrey
    Car:
    W212 E63
    I had a fuse blow. Very odd in a W211 there is nowhere that tells you there are fuses under the bonnet. The handbook and the fuse guide only mention the dashboard and the boot. The 12 volt socket in the front, the one I use for charging phones etc is a 15a fuse under the bonnet!
  9. OP
    OP
    CiaranMcKeown
    226
    Sep 11, 2007
    Belfast
    Car:
    C220 CDI Black
    Thanks i got it, very tight squeeze to get a grip on it where it is under the bonnet, its right at the back of that box almost underneath the wiper mechanism, but, i got a grip of it neway and it was blown, cheers everyone.
  10. SimesH
    SimesH New Member
    6
    Sep 28, 2009
    Are fuse-box diagrams some sort of holy-grail in 'Mercedes land'?
    Every thread I've checked, looking for a '97 Sprinter 208d fusebox schematic (the box under the steering column) seems to finish in a dead-end :crazy:
    Loads of useful suggestions, but no diagram :(
    Simon :confused:
Tags:
Share This Page
