Fuse location
jjg
Does anyone know which fuse operates the Cigarette lighter on a W203?
the cigarette lighter is powered from a 15Amp fuse 47 in the engine fuse box -the glovebox lightswitch is powered from the same fuse 47. That fuse is in turn fed from relay4 in the same box which in turn derives its power supply from a 200A fuse4 in the smaller ENGINE maxifusebox the 200a fuse is unlikely to have gone or you would have more problems
Thanks for the info. I'll check it when I get home. :thumb:
