R2D2 said:Grav, when are you leaving for Torquay?
The G tech is still in my boot
About 10 hrs before you posted the above.R2D2 said:Grav, when are you leaving for Torquay?
stats007 said:Er no offence but a trip back to school may be in order! Hot air balloons rise because of buoyancy - principly the weight of the air in the balloon is less than the weight of the air it has displaced.
I think you mean higher density cooler air.
Silvertank said:I've been enthralled by this thread so I bought a g-tech specifically for my 300TD.
As I type I'm sat in the car accelerating waiting for my first 0-60 time. When I reach 60, I will post my results - this could be sometime tomorrow or the day after depending on the weather and the wind direction LOL![]()
Lets hope the tank of diesel holds out for the run.![]()
Hopefully you will finish typing before the vehicle reaches 30 mph?Silvertank said:As I type I'm sat in the car accelerating waiting for my first 0-60 time. When I reach 60, I will post my results -
Too strong a head wind!!scumbag said:where we at now?![]()
Hi Ian,i_york said:I did a few runs and here are the results...
0-60...........4.65
1/4 ET........13.08 @ 109 (2.0 60' time)
My mate scumbag said:Right, the best i got was 4.82 and 2 other runs sub 5 seconds.
the fastest run was set in C mode! it was 4.91 in S. but for some reasons on the road we used i had traction issues on change up to second.
glojo said:Hi Ian,
That is a really impressive 0 - 60mph time. Is your car a standard CLK?
I ask this because Scumbag's car is a real lean, mean flying machine, but his car appears to be slightly slower?
Regards,
John the curious
Hi Ian,i_york said:Looking at Scumbag's post, my launch technique was a little more complex... traction control off, brake-stall to 1,500rpm and roll-on the throttle off the line in order to minimise wheel-spin in 1st. Stamping on the throttle results in wheel-spin all the way through 1st gear.
