Garage clear out - w124 and 190e parts.
p1RATE
Leicestershire
Pink/Purple 190e
I'm getting rid of all the stuff sat in my garage and there are is a small mountain of Mercedes parts in the corner. I have added some terrible quality photos taken on my useless phone now for each. As for price ill just see whats cheapest on ebay and match it, feel free to make an offer.
190e parts -
Front electric window motors
Gear knob [1]
Gear stick leather gator with purple stitching [1]
e300 front brake calipers [1]
Front anti roll bar from a 1.8
Rear taillights
n/s passenger wing mirror in blue/black [1]
Exhaust back box 1.8 [1]
Rear view mirror [1]
Headlight switch (04 8434 20) [1] [2]
Headlight switch surround [1]
Wood Gear Stick surround without electric window switches [1]
Pair of amber indicator reflectors [1]
First aid kit [1]
2x radiator caps [1]
Car jack [1]
Electric Window Switch (124 820 46 10 kz) [1] [2]
Electric Window Switch (124 820 45 10 kz) [1] [2]
Pair of horns [1]
1.8 Manifold [1] [2]
1.8 Radiator (needs a flush as its full of head gasket gunk) [1]
1.8 Radiator shroud [1]
Grille Slats 4 vertical 2 horizontal [1]
2x unused ball joints [1] [2]
w124 Parts -
e300 automatic gearbox
e300 Manifolds (m103) [1]
e300 Alternator (M103) [1] [2]
e300 Starter Motor (M103) [1]
e300 engine fan (M103) [1]
e300 dip stick (m103) (126 270 00 83) [1] [2]
e300 Ignition Module (006 545 76 32) [1]
w124 climate control unit (462 002 200) [1]
300e ECU (0 280 800 206) [1]
w124 indicator/combination/wiper Stalk (124 545 02 24) [1] [2]
w124 bonnet release handle [1]
Hand break leaver [1]
Heating Ventilation switch (124 830 01 85) [1] [2]
Heater control switch (124 820 22 10) [1] [2]
Wood Dash panel for heater switches [1] [2]
Wood gear selector surround [1]
Sunroof Switch and cabin light [1]
Ignition surround [1]
Water Valve (000 830 6584) [1]
w124 wood ash tray [1]
ABS Control unit (0 265 101 020) [1] [2]
Rear window heater switch (124 820 10 10) [1] [2]
Hazard warning switch (124 820 01 10) [1] [2]
w124 e300 master cylinder & brake booster (002 430 9830) [1] [2]
w124 front headlights [1]
w124 rear taillights (Saloon) [1]
w124 Window wiper motor and stalk. [1]
AC condenser (m103) [1]
300e down pipe [1]
e300 drive shafts [1]
e300 radiator [1]
e300 radiator shroud [1]
new radiator hose (124 501 94 82)
Auto Gear surround
w124 ash tray
Front anti roll bar from an e300 w124
The parts are in Hinckley, Leicestershire and i can certainly sort out postage on some of the smaller items.
Hi is the 190e gearknob still available? And is it a manual one, with the pattern of reverse lift and down to the left?
Cheers
Garage clear out
Hi
I've sent you a pm. Do you still have the duo valve and is it in good working order?
Richard
front headlight facelift passenger side if yes only need lens if possible
Hi Pirate,
Is the anti roll bar for the 124 from a standard or sportline spec vehicle please?
aybracers said:
Hi Pirate, Is the anti roll bar for the 124 from a standard or sportline spec vehicle please?
Hi do you have a cigarette lighter, just the bit that pulls out please. Cheers
