Gas pipe size.
Discussion in 'OT (OFF Topic) Forums' started by marty359, Dec 29, 2008.
  1. marty359
    marty359 Hardcore MB Enthusiast
    898
    May 24, 2005
    The Fens
    Car:
    BMW 330d with indicators and Jeep Renegade also with indicators
    Seasons greetings, Im taking advantage of the sales and fitting a new kitchen and want to keep the electric oven but change the electric hob for gas.
    We have a 30m run of 15mm gas pipe from the meter at the front of the house going all the way to the boiler at the back via the kitchen.Im not sure of the the rating of the boiler but it feeds 10 rads,will the 15mm gas pipe be big enough to run the boiler and a 4 ring hob?
    Thanks in advance Marty.
  2. grober
    grober MB Club Veteran
    27,593
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    I think most gas boiler installers would put in a 22mm supply pipe as a minimum now. Some boiler electronic controls are sensitive to gas supply pressure and if you were to run the 4 rings plus boiler you might begin to get boiler control problems? There are some heating engineer members on the forum so no doubt they will be along to confirm/deny this shortly.;)
  3. Darrell
    Darrell Hardcore MB Enthusiast
    3,907
    Dec 15, 2006
    Back in Mill Hill but sometimes in Skiathos
    Car:
    A Jaaaaag, 2016 Dacia Duster and a 2004 Carrera (996)
    Run a new supply from the meter in 22mm and reduce down to 15mm as near to the boilier and hob as you can.
  4. OP
    OP
    marty359
    898
    May 24, 2005
    The Fens
    Car:
    Thanks for the replys, Its a pig of a route if I had to change to 22mm it goes through 4 rooms and the upstairs landing:( and doing it surface outside would look crap.
    Oh well...thanks anyway.
  5. portzy
    portzy Hardcore MB Enthusiast
    1,580
    Apr 10, 2004
    Ulrome, Driffield, East Yorkshire.
    Car:
    An SLK R171 with lots of toys and a Golf Plus for fishing.
    I think that you would be pushing things a bit with so much 15mm. I take it your boilers' not a combi?
    Portzy.
  6. OP
    OP
    marty359
    898
    May 24, 2005
    The Fens
    Car:
    No portzy its an ancient glow worm space saver with an indirect tank:confused: where the central heating heats the hot water.
  7. portzy
    1,580
    Apr 10, 2004
    Car:
    I reckoned so. You are really on the limits with so much 15mm even to the present boiler, I'm guessing its in the region of 50,000 to 60,000 btu (15 to 18kw) input and believe it or not the average hotplate could well be nearly half that on top again. It would be best, at least, to go to the first appliance with 22mm then reduce down to 15mm for the next. As someone has said, if you drop the working pressure too much the burner(s) could malfunction and cause poor combustion, although the Space Saver was a range rated boiler and is quite tolerant to different input pressures, the output will suffer.
    If you intend to ever get a combi though, expect to have all 22mm and possibly a bit of 28mm from the meter.
    Portzy.
  8. poppypiesdad
    poppypiesdad Active Member
    86
    Jan 17, 2008
    Cupar Fife
    Car:
    Vito 108 Dualiner
    i know its a pig but repipe it because your bolier will pack in one day and you'll have to do it :(
  9. joe
    joe Hardcore MB Enthusiast
    264
    Jun 20, 2003
    Liverpool
    Car:
    W203
    There are charts for sizing gas pipes. (If I can find the charts/calculations I will scan and post) Pipes have flow rates, bends and fittings reduce these rates.
    Basically you should not have more than a 1mb drop at appliances (take meter pressure)
    You need to size your appliances by reading the data badge or calculating a gas rate when appliance is working.
    Correct Gas pipe sizing is part of Gas safety Regs.
    Good Luck
    Joe
  10. OP
    OP
    marty359
    898
    May 24, 2005
    The Fens
    Car:
    :D I only wanted a new kitchen.A ceramic quick plate hob thingy will be fine.
    The boilers lasted well and when she blows i'll have it all done in one hit.
Tags:
Share This Page
