BTB 500 said:I've used the long term parking in the airport half a dozen times without any problems, it's cheaper if you pre-book (your number plate then gets read & recognised as you go in) plus you know you've definitely got a place ...
http://www.parkingexpress.co.uk/
GrahamC230K said:I use the (probably most expensive) indoor car park where you keep your keeps and walk straight into the main terminal.
stats007 said:Settled for a night in the Holiday Inn and valet parking in their private CCTV'd and gated car park for £115. Hopefully it will be fine when I get back!
