Gauges light change
kevinE200
Can anyone tell me how I can remove the instrument cluster and change the burn out light for the gauge for my 1998 W210 E200 please? I search couple of discussion forums but I got no luck!
On a W202 the easiest way is to remove the lower dash (where your knees go) and then stick your arm carefully up inside the dashboard to the instrument cluster and then gentle push. It is only held by friction.
Failing that their are two other methods, one involves having the correct MB tool and the other Involves removing the steering wheel!!!
let us know how you get on.
