botdoc
I took my car to the dealer with a 'loss of power' problem on hard acceleration and it was subjected to the usual 'star diagnostics'. I was told that the gear-box controller was duff and it needed replacing (£389 + VAT) and awaited the parts. When it arrived it was plugged in in place of my old controller and taken for a test drive with no discernable improvement. Then it was noticed that my air-intake hose was collapsing and concertinering on flipping the throttle. Taking the pipe off the front attachment (which had broken allowing it to collapse down), the car behaved like new and I drove away with a lighter wallet.
Since then, the car had dropped into 'limp home mode' (2nd gear) only once but it was more than enough!.
The dealer had fortunately left me the old controller which I changed back to and it drives as if I had just left the garage the first time. The part number on my old controller is A 030 545 20 32, whereas that on the new one is
A 030 545 23 32. Would this matter?
Also, my ABS / ESP light keeps coming on intermittently, usually after the engine has got hot in standing traffic, and it requires tunring the engine off and restarting to eliminate the message. I have noticed that my cruise-control disappears during times when the ABS / ESP lfailure lights are on. Is this just liekly to be the mysterious 'brake switch' or something more expensive.
Would I be unreasonable if I asked the dealer to take back the new gear-box controller on the grounds that: 1) changing it didn't seem to fix the problem (replacing an air intake hose did instead) and 2) the gearbox has locked into limp-home mode once after having had it changed which it never did before?
Thanks for any advice.
