Hello, didn't want to hijack this thread http://www.mbclub.co.uk/forums/showthread.php?t=67937 then I open another one,
Where can I look/ see/ check the vaccum lines / actuator (whats that?) on the E300TD? Just wonder as my gear box as a kind of rough change sometimes. I mentionned it before. It also feel sometimes like there is a wheel spinning inside with a momentum, then it goes in gears, hard to explain. The oil is new ish and at the right level.
Could it be that the silentblock is out as well? It was a wee wobbly last time the car was up, might need a new one?
Or the enging mount rubber thingy?
Thank you
Thank you
