gearbox going to F mode -A168 52 plate
mattc
Midlands
Audi A4, 1994 E320 Coupe, 1995 E300 estate
Neighbour comes over today and says his wifes A class has just started playing up. Auto gearbox is showing F in the dash. I sent him off to get it read on a STAR machine - this is what it said.
Can the jury tell me what they think is wrong please. ATF was checked (how do you do that on an A class?)
cheers
Matt
It will probably need a new selector module.
There is another code which is interesting. The low pressure one in FTC. This maybe a valve body on the way out or a solenoid fault.
Top tip: NEVER buy a auto 168. They go wrong all the time.
Yes - I know this Olly but its a bit late for the neighbour!
What should the cost be to change the 2 things you mention? Would that solve the F code problem or could there be other issues lurking 'behind' what you see on that sheet?
No other issues that I can see.
Just change the selector module. That should sort it.
It will need coding with a Star too when fitted and make sure all of the codes are erased.
Ok...so where does the selector module hide? How much/long to fix?
It is the gear selector lever and the module it attaches to. W/S switch attaches to it.
How much for the part? I am not too sure. Less than £500 I think???
Fitting takes at least an hour.
Cheers Olly
I will check with Merc tomorrow for prices. Is it all accessible from inside the car - i.e. remove centre console and locate from there (sorry for the Alexandre Dumbass questions but I have no idea about A classes)
Below is the report from the garage and their diagnosis:
"In our opinion with the fault codes which are present we believe that there is a damaged clutch pack inside the gearbox which is causing the problem. We recommend that the gearbox is removed and the relevant parts replaced"
