W203Wanderer
Hello all,
I own a c180k w203 2006. 110k on the clock. Mercedes. Driven it for three years, pretty much problem free up until recently, where I lost all power to the transmission, clutch was slipping, The reverse gear would not engage in the park gear would not engage, One thing led to another and it was ruled that the valve body needed replacing, I then bought a reconditioned gearbox and had it installed. It works, it cycles through the gears no problem at all – but there is a slight issue, there is this noise from the gearbox most noisy when under 30 miles an hour, is this something I should worry about?
thanks all
thanks all
Upload MP3 & MP4 Music. Free Mp3 Hosting With Direct Links
Upload mp3s free: hosting for music, mp4, mp3 tags and images. Free Mp3 Storage that is simplest and easy to use.
www.mboxdrive.com
