Gearbox oil leak
Discussion in 'Engine' started by Alps, Dec 15, 2008.
  1. Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    E55 2004 Silver, E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
    Left the car in situ for the last couple of weeks, and upon driving it out the garage spotted a little patch of clean red oil from the area of the gearbox sump.
    any ideas what could be the cause? my indi ais a 60 mile drive away, so will it be safe to drive? or should i top up the trans oil a little before heading out?
    it didnt pour out it only dripped, about 2 tablespoons worth over the 2 weeks, overnight it dripped one spot.
    any advise, ideas, possible causes would be great!
  2. Adam230K
    Adam230K MB Enthusiast
    3,087
    May 1, 2007
    Car:
    German oil burner
    I'm no expert, but if its hardly losing any, you should be fine driving to an indy and getting it checked... but it sounds like your seals... unless its done this before?
  3. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    Probably the electrical connection socket leaking and dripping down the box.
  4. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    hi DM, is this easy to replace, do i need an indy, or is it a diy job? maybe i should order the part in advance in case thats what it is?
  5. Ian B Walker
    Ian B Walker MB Enthusiast
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    If it is this item it is easy to change by yourself.
    Tools needed. 7mm small long socket.
    Pilot bush, £7.
    Undo electrical connection.
    Undo 7mm centre nut in old bush.
    Pull out bush
    Push in new bush and carefully tighten. Warning, do not over tighten.
    Replace plug, job done.
  6. Shaun's C280
    Shaun's C280 Active Member
    83
    Dec 14, 2008
    Weedon Bec, Northampton
    Car:
    1996, W202, C280 Elegance Auto
    Any chance of a 'HOW TO' anybody on W202 4 speed Auto?
  7. vijilants
    vijilants MB Enthusiast
    2,225
    Jan 23, 2007
    London
    Car:
    C320CDI Sport W204
    If it is the electrical connection, Id also check the gearbox ecu aswell. The fluid travels along the cable and lands up in the ecu.
  8. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    Ian, is this a jack up and underneath job? also... whats the bit i ask for at the parts counter:) thanks in advance
  9. vijilants
    2,225
    Jan 23, 2007
    London
    Car:
    C320CDI Sport W204
  10. Shaun's C280
    83
    Dec 14, 2008
    Car:
    Is there a specific ATF that I should replace it with?
  11. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Dexron III spec or equivelant will be fine.
  12. Shaun's C280
    83
    Dec 14, 2008
    Car:
    Thanks Dieselman :)
  13. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    thanks for all the replys guys, esp the link desilva, doesnt seem that big a job, so will do it at the weekend, apparently its the same part across the range and the local stealer keeps a box of them on the shelf.
    £14.10 + VAT
  14. c240yaz
    c240yaz MB Enthusiast
    1,096
    Jun 21, 2007
    My sump gasket seeps, even with the bolts torqued to correct nm. and that was after an ATF and gasket change last year.
    I just live with it till the next change in a few months time.
  15. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    ok, changed the electrical plug guide this morning, the guides on benzworld are pretty spot on. it was pretty messy down there, as i also have a small engine oil leak, cleaned it up after the change, and will check again next week to make sure ive diagnosed it right.
    leaked abt 600ml of atf whilst doing the swap, so i replaced that and a little more to account for the leaked fluid.
    still cant get a reading with a homemade dipstick, so im gonna buy a proper one.
  16. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    just Jacked the car up this morning to make sure nothing was leaking, i found it was still leaking but not at the electrical connector, but at the back of the gearbox, a couple of drips off the rear mount, any ideas what could be leaking from the rear of the gearbox?
  17. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,808
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    I suspect it's the sump gasket or rear oil seal.
    BTW use MB ATF. Dextron III is NOT good enough.
  18. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    thanks ollie, most prob the rear oil seal as the sump is still free of oil since cleaning it, is this a big job?
  19. OP
    OP
    Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    Ok, just had a call from my local indi, and it was leaking from a rubber block near where the shifter enters the box!?!
    Thanks for all the suggestions guys!
Tags:
Share This Page
