guydewdney
The gearbox in the GF's sprinter (722.3) is playing up
symptoms:-
drives off perfectly in 1st or Reverse
changes up perfectly when cold
when hot (10 miles? driving) drops a gear - as in it no longer drives the only gears to engage are 1st and 2nd.
2nd at 4000 rpm = 35mph
push lever to N for a second or two, then back to D and it sometimes engages 3rd or 4th - continue for a bit, then it 'drops' it again.
Ive just replaced the transmission fluid inc the torque converter, no change.
This suddenly happened yesterday night. It has been 'flaring' between changes in 3rd to 4th - it no longer seems to do that with the new oil.
Removing the kickdown cable (or 'control pressure cable') and / or the modulating pressure pipe makes little to no difference to the problem (it does make a difference tho' - just doesnt affect the 'wont go out of 2nd' problem
Any ideas?
Aparantly the B2 piston problem doesnt affect gearboxes this late (its a S reg 1999)
TIA
Guy
symptoms:-
Any ideas?
TIA
Guy
